kchap
I'm running into a similar issue. I am using an RTD to read the temperature of a large kettle. We recently installed a new mixer in the kettle...a setup I have not seen before. The mixer motor (30 HP) is wired for 240V, but it is driven by a 480V VFD. The RTD is about three feet away from the mixer. Any time the mixer runs, the temperature value decreases by four degrees. We are using shielded cable with the drain wire grounded on the PLC end.
No one in our maintenance or engineering departments has been able to figure out what is causing the drop in temperature value, but it obviously has something to do with the new mixer. Does anyone have any insights as to what might be going on?
