THEBESTBOBEVER
Had a project a few years back done in v14 of TIA.
Very similar job has come up for the same company with different PLC and HMI hardware.
I attached some screenshots of what I'm dealing with...
First is the plc type, Cut sheet says i can use a different model number in older versions of TIA, seems weird...
Second, when i select the PLC and attempt to change device, I'm not given the option to select what i need. (highlighted on the right in device library)
I don't have much experience with Siemens (typically AB and Mitsubishi)
Any help would be greatly appreciated!
