Tia v15.1 uploaded project differs in online
Roju
Jul 2021
Krakow
18
I have to upload a project from Siemens CPU1214C that contains PLC,HMI and 2 drives I5500. I was able to upload device as a new station (software and hardware).
So program blocks got downloaded, hardware configuration also - but without HMI.
And now situation looks like this, if I go online, it shows that the downloaded blocks are different than online version. Also hardware shows that it is different than online project ( I guess because HMI didn't get downloaded). Is there a way to get it match? I do not want to risk stopping the machine to add some minor thing because of those differences.
+My second thought is that the hardware and HMI doesn't matter because i do not want to change any of those. But it would be nice to know if I download the correct version of software.
Perform an offline/online compare. The comparison result will list what the differences are.
One thing that messes things up is if you select a different language in TIA than what the blocks where made with.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
460
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
360
Hi am new to TIA and i have a challenge when i archive the project it;s being saved as PDF. How to l change from PDF to normal TIA. Your...
611
Is there any possibility to convert the project in TIA V17 Wincc Professional to TIA V15 Wincc Professional or Wincc Advance?
1,245
I have 2 TIA Wincc projects. One project is in TIA V17 Wincc Professional and other project is in TIA V15 Wincc Advance. How can I copy the Wincc...
1,252
