TIA v15 import drive
Holmux
Oct 2013
Aalborg
279
Dear List
I am starting my first project from scratch in TIA, I just purchased a TIAv15 and is starting to get my feed whet.
First thing I am trying to do is import data for a S110 CU305 drive to my hardware list, is there a simple way to do this?
/Holmux
According to Siemens webpage for STARTDRIVE V15.1 (https://w3.siemens.com/mcms/mc-solutions/en/engineering-software/startdrive/pages/startdrive.aspx) only these drives are supported:
SINAMICS G120 - The modular single drive for small and medium output ranges
SINAMICS G120C - The compact single drive with a low power rating and appropriate functionality
SINAMICS G120D - Distributed Inverter for Cabinetless Designs
SINAMICS G120P - The specialist for pumps, fans, and compressors
SINAMICS S120 - The flexible, modular drive system for sophisticated applications
SINAMICS S210 - The servo drive that simplifies project engineering for machine builders a lot
So in order to get an S110 drive into your project, you have to import the GSDML file. And the actual configuration of the drive should be via STARTER.
Jesper
Updated my response
Starter is indeed required
Startdrive doesn’t support S110
Never will since S210 fully released
Thanks very much for the reply
I did an update of the hardware catalog and the drive showed up in the search :)
I have done a few S110 drives as standalone installations using the starter software, but for this installation I have a ET 200SP in the same cabinet and I was planing on controlling as much as possible via the PLC, is there a block I can throw in where I can handle the basic tags in the drive?
Or do I hardwire some IO to the drive to control it?
The drive and CPU are both Profinet
/Holmux
There are a variety of different drive blocks out there for different Profinet telegrams. Some are included in the Portal install, and I think more are available on the support site.
You can also probably set it up as a technology object in the PLC (assuming you're using one of the newer 1500s). Personally, I prefer this method, and find it a little more intuitive.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
449
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
358
Hi am new to TIA and i have a challenge when i archive the project it;s being saved as PDF. How to l change from PDF to normal TIA. Your...
609
Is there any possibility to convert the project in TIA V17 Wincc Professional to TIA V15 Wincc Professional or Wincc Advance?
1,242
I have 2 TIA Wincc projects. One project is in TIA V17 Wincc Professional and other project is in TIA V15 Wincc Advance. How can I copy the Wincc...
1,251
