Time sync between WinCC 7.0 and S7-300 PLC
mikas_m
Feb 2007
ck
154
Hello to all,
I have one wincc operator station (version 7.0) that is used for monitoring and control of the process via S7-315 PLC. This Wincc application stores data in the database and doing some simple math.
However, the problem is the lack of synchronization between the PLC and WinCC. I found that from time to time I need to open a menu in Simatic manager and to click on the option "Take time from PC/PG".
Basically I need PLC to use time from WinCC (and Wincc uses the windows clock). This would be perfectly fine.
Can anyone help me in explaining or point out to a manual how to make this synchronization?
Thank you
hi guys, can someone guide me with this? i'm new to TIA portal, please provide more approachable guide that i can understand~~ Thanks alot!!
4,810
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
54
I have to start out by saying I am not a PLC programmer and I have basic programming skills but mainly use software as a troubleshooting tool. I...
134
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
224
Hello, I am trying to create an AOI that will retrive the clock datetime bits from a master plc through a generic message read instruction and...
499
