Totalflow Log Period
Ones_Zeros
Feb 2014
at work
367
Ok Totalflow gurus
I've been having to work with totalflow registers
More & more these days.
I would like more understanding about them
If someone can help explain
Today we were discussing "Log Periods"
We have ours set on 60 min log periods
For example the totalflow register "Today's Volume"
Is a total accumulation based on contract hour and
Then becomes "Yesterday's Volume" after contract hour
Turns over.
I understand this flow total changes every 15 seconds
In the totalflow...I think that's right. Is this called clock cycle?
So does the "Log Period" mean that after that hour ends
It averages this changing flow for that hour & it gets logged
As a flow value for that hour?
Thanks guys
For being patient with me
I appreciate the help
They describe the integration methods in the manual fairly well and even show the equations.
It depends on which equation was picked during setup. Basically five different settings that give different results depending on how the unit is configured.
Note: This is based on 20+ year old knowledge of when I used to work for the company that owned Totalflow back before ABB bought them. Man I am old... :cry:
I can't seem to figure out how to add descriptors to I/O points on an RMC using PCCU. Say, for example, I want to use "Valve_1" as a descriptor...
81
Hello, I am working on setting up a totalflow G5 and I would like to use the Alarm application. I have most everything setup, but I was wondering...
302
I've got a G4(board only)with a MMI port problem. I do not know the IP, but I believe that port works. Is there a way to reset the device to...
579
I'm trying to look at some G5 and XIO configs offline with PCCU and I understand that I need a simulator for that purpose. I haven't contacted my...
785
I'm new to the TotalFLow XIO and it has an attached TFIO DI/DO combo module. All I'm trying to do is close an output on the TFIO module. I'm...
625
