Touch screen connection between mitsubishi & keyence
sttchui
Mar 2008
kl
81
Does anyone know the wiring connection between keyence touch screen vt-7sb to mitsubishi qseries q02hcpu port???
Actually it quite an old unit, it is VT1, i try to configure it to connect Q02HCPU using the RS232 port to link with the VT-7S,
i have check the keyence touch screen it only can communicate with Q series PLC(Q mode) using CCU communication instead of Direct CPU for new VT3 unit which can communicate with Q02Hcpu
Now i stuck with the same problem, i can either replace the touch sreen or try configure to link with CCU communication but i do not have any idea or how the wiring for the CCU communication????
Do you have any information reagrding CCU communication?
Thank you!
Regards
sttchui
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
108
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
153
I have a managed InTouch Application that I deployed changes to through Archestra IDE yesterday. The only changes I made was adding a solenoid...
108
Hey all! Long time reader, first time poster! I have an EA9-T7CL and an MicroLogix 1200 connected via DF1. I'm all good and got everything mostly...
659
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,475
