tp170b
sergeill
Feb 2008
ekaterinburg
hi
i tried to download project into tp170b through routing actually ive never done this before and my experience with panel is limited. but before i downloaded a project via rs-232 and it was connected to 315-2dp by mpi. it worked fine. actually what i did was reconfigured this connection in netpro to profibus and added pg/pc as was written in a manual and repluged the panel to profibus,while pc was connected to mpi through usb adapter.and i did all appropriate settings in the panel itself enabling profibus channel for transfer.im qute sure evrything is ok as to communication settings of all nodes but it still wont transfer cause it "cant establish connection to this module". and when i run diagnistic the message is the same. what can i be missing. actually a previous project was left in the panel. im not sure whether it can cause any problem. and i turn the panel to transfer mode, though i checked the box for remote control.
Dear Friends, i have a problem with a Siemens TP170B. I can't transfer my project by MPI of my PC. Error Message in attach. I can't resolve the...
3,942
Hi, Recently I was forced to replace a S7-200 CPU 226 on an old machine, which was defected. Unfortunatelly the old cpu was password protected by...
1,702
Greetings i need to do programming / configuration for a new Siemens TP170B what connection cable do i need ? if it is attached to Siemens...
2,421
Hi Im using Compact Logix L32E PLC and Siemens TP170B HMI using Win cc flexible.How to communicate between this two? There is no Ethernet port...
3,381
Hello, I have a service engineer on site, and he is struggling with a touch panel. The touch pointer is way off where he is pressing the touch...
4,525
