TP177B_PN_DP Demo
automatt
Dec 2006
Cornwall
I'm currently working on an HMI project using a TP177B_PN_DP and programming with Wincc Flexible 2005.
I can only find an example project on the Siemens site for use with Wincc Flexible 2007.
Would it be possible for someone to open this with 2007 and save it as a 2005 file and post it back? Or point me in the direction of a 2005 demo file?
Thanks,
Matt
http://support.automation.siemens.com/WW/llisapi.dll?cspltfrm=0&cssw=19&csbinh=0&csquery4=&aktprim=4&extranet=standard&func=cslib.csinfo&lang=en&objaction=csbrowse&objid=20229806&siteid=cseus&subtype=136000
Have you uploaded SP1 and HF7 for 2005?
I think Ethernet-connection is not possible becourse it can't
build HMI IE for TP177B_PN_DP without servicepack,
there is HMI MPI/DP only.
I get the error message when I try to open the project. It says something like "The project was created with an incompatible or beta version. It was last opened with WinCC flexible 2006"
The demo projects for are for 2007 version only. They need to be converted with the new software. I will try after I install my 2007 version.
demo for 2005 version
I can not upload it as it is 8MB. I can email it to you if you send me your email address.
Hi everyone I'm having trouble transfering a projec from my PC(wincc Flex 2008 sp2 Win7) to an HMI simatic panel(tp177b pn/dp 6"cstn). I 've...
3,582
Hello, as you might know, the TP177B is no longer in production. However, we do have a lot of them in our machines, so some spares would come in...
19
5,039
hello dear all. As a project the customer ask me to translate all texts to persian but the panel TP177B COLOR PN/DP shows squares instead of the...
1,334
Dear all, We have two machines and we have the same sytem running on the both, and TP177B 6" color HMI is installed on both, one of them got some...
2,547
hello i have system with cpu315f DP and HMI TP177B DP 6 inch it`s first time to make configuration for hmi with s7300 so i have some questions...
1,530
