Trying to translate a .RSP file for Studio 5000
GlenOsborne
Sep 2017
Clewiston, FL
I have Studio 5000 as well as the "Translate PLC-5/SLC 2.0" tool. However my SLC-500 file is in .RSP format.
I don't have the RSLogix 500 to save as a .SLC and export the .TXT. Is there a tool to allow me to do this?
Thank you,
GlenO
I think .RSP is PLC-5 so you would need RSLogix 5 or someone will come along and convert it for you.
Oops, I think you are right. For some reason I thought that the PLC that is existing used the same programming as the RSLogix 500 but the icon in the Translate program looks like the existing hardware. So it looks like it is RSLogix 5. Thank you for the info.
Now I guess I need .CSV file
KuulKuum got the file translated for me, but it looks like it doesn't have the descriptions. I don't know if this file had item descriptions but I hope so, otherwise I will have a bit of a problem figuring out what everything does.
I also downloaded what I suppose is an upgrade from the translate tool and got the Project Migrator.
There's no comments in that program so you will need a copy of the original or a copy of the commented program. Comments are stored on the laptop not in the PLC.
I see. I guess I'll be running down ancient subcontractors then as I am afraid that this file is all that the department of transportation had to give me. This may be a bit trickier than I imagined. Thank you for your help.
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
137
Hi I used to be able to launch PLCsim without any problem. Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
535
Hello! When trying to load the hardware configuration I get error 0050-133 2 2458, check the diagnostic buffer. When checking the buffer, it says...
187
We have a keg check weigher that that lost a fight to a forklift. The scale was previously a Systec IT3000, which was the only PROFIBUS slave...
676
