Two Encoders to One Input
ndzied1
Aug 2002
Chicago, Illinois
2,857
I have a customer looking for a device that will take two encoder signals in and then let you select between them for the output. I guess we could use a series of relays or switches but he swears he has seen a device like this before..
I have found a lot of encoder signal splitters but not any devices that I would classify as multiplexers.
Does anyone know of such a device?
as far as i know its not possible to do this, i even just called my former co-workers at Omron tech support to see if they had a solution - and they said its not possible to tie in 2 encoders to a single plc input.
the reasion is because even if its a highspeed input - the scan time needed for the plc code to differ between the two sets of pulses would mean that every time you switched between the 2 encoders you would lose a few pulses and your position would get futher and futher out of alignment.
as far as i know you always have to have each encoder tied into its own highspeed input
I'm not looking to have both encoders attached to the input at the same time. I'm looking for a device that will let me switch between the two encoders. Sometimes they want to use encoder 1, and sometimes they want to use encoder 2.
I think I found the device:
http://www.dynapar.com/uploadedFiles/Products/Heavy_Duty_Encoders/RIM_Signal_Switcher.pdf
There is no connection diagram shown but from the description, it fits exactly what I'm talking about.
Lol, look at the pcb. Three double pole changeover relays, a voltage regulator and an opto isolator for the change over signal. How much are they charging?
You could build your own unit very easily (just use gold plated relay contacts)
I love the "Fail Safe" feature; ie the normally closed relay contacts!!
You could build your own unit very easily (just use gold plated relay contacts)...
At a previous employer, we did exactly that. We used a fairly common Square D plug-in "ice-cube" relay with gold contacts. It was also for an encoder selector set up and not switched while in motion, but only during set up of the machine.
Paul
Firstly, WHAT is the reason to do this? I know of some, but give a hint about the application, and WHY it's necessary.
Secondly, must this be done "ON THE FLY" (as in, while something is in motion?) or can it be done while at stop?
I ask this, because I've had many situations when we needed to use an encoder to provide feedback for a master line control drive, and another one to provide feedback during a jog operation when the master drive might be inactive.
Is the client looking for something strange? Like wanting to control by either RPM or FPM? based on a motor tach or surface tach?
What are the pulse frequencies involved? if on the fly switching is required (poor control system), then just put together a little circuit board with some AND gates on it.
What voltage levels?
Welcome to my world:
I don't know
Don't know for sure but probably at a stop
Pretty much my whole life
I don't know
I don't know
I don't know
Not on your life. If I build it it's mine forever, if I sell a manufactured component, I get to blame the manufacturer.
24V Differential Line Driver +A,-A,+B,-B,+Z,-Z (Yea, one I know)
This exercise has given me the knowledge to ask the customer more questions and get them the right answer. I'm hoping he wants change over at a stop and then I'll use 3 Form C Relays with gold contacts and a selector switch and be done with it.
No, thank you for the response.
But those questions need answering.
We can help you, if you have answers to the above.
Look seriously at my questions above... Ask your client. Tell me WHY, and I'll potentially give a solution, or someone here with a real brain will help ya.
Paul
At my previous employer there was a machine that did this as well. Just a plain old ice-cube relay. The machine was a basic indexer punching holes in angle. While punching a hole, it would switch between the front encoder and the rear encoder so that there would be zero drop.
I didn't build the machine and I swore that it was a bad setup but the relay encoder switching never caused a bit of trouble in 10 years.
...I didn't build the machine and I swore that it was a bad setup but the relay encoder switching never caused a bit of trouble in 10 years.
Yeah, I did not design the circuit that way either, but discovered it during troubleshooting and found someone had plugged in a normal relay without the gold plating which eventually caused some encoder loss errors. It was just one four pole relay with Form-C contacts.
I asked myself then "why would anyone do this?", but it was the only time it ever gave any trouble on apx 15 machines that used this circuit.
IIRC, it was used to select from two different supply conveyors measuring stock into a tire building machine. It only switched when the operator emptied one roll and switched to the other let-off unit. Probably 20 times per shift.
Paul
This one switched about once every 45 seconds all day. It was a 12VDC encoder...maybe 15VDC, so I don't know how well it would have lasted at 5VDC. Still I wouldn't say it was good setup but it is possible
I later replaced the controls for a Controllogix with a M02AE for the two encoders and tied the two channels -10 to +10VDC outputs to the drive.
I was wondering if 5032-8IOLM12DR are suitable for encoders devices. I'm concern about the RPI and loosing encoder counts using this type of...
125
I'm thinking to have a 5032-8IOLM12DR and encoders plug in to them. I'm concern about the RPI and loosing encoder counts using this type of...
98
First time poster here so long story short i built my own trainer at work so i could toy around with various things and test things and learn...
25
2,190
Good Morning , We have a large machine with a number of shafts , and I would like to monitor those to make sure they are constantly...
2,143
Hello Experts, I have a Turck Encoder connected to P+F IO Link master communicating over Ethernet/IP with Allen Bradley PLC in Studio 5000 v34...
738
