drbitboy
If you did not correct the off-by-1 error of post #21, then it still may not be working correctly yet.See above. I got it working.
Thanks for all the help!
Are you sure you are pairing the correct low-word, odd-address Modicon value with its corresponding high-word Modicon value (near 17024)?
If all of the pressures are roughly the same, then the error would be less than 1%, so you cannot tell by looking at the resulting floating point values.
Bookkeeping. Just trying random things until it "looks" right, which is pretty obviously what was being done, is not enough.
