unable to upload from CPM1A OMRON
lachuupriya
Dec 2010
F**K Land
Hi everyone,
I'm trying to upload program from CPM1A - 40CDR - A - V1 OMRON PLC. But my bad luck unable to get program.
PLC: CPM1A - 40CDR - A - V1
Expansions: 8ED, 8ER
Communication Cable: CPM1-CIF01 + UC 232A
Software: CX-Programmer 7.3
PC: IBM ThinkpadT43
I tried my best to pull out the program but always I fail in it.
I tried Auto Online and Manual Online (Create Blank Project and tried connecting online)
I have chosen correct COM Port, Baud Rate and Network Type.
I tried "Scan Serial Ports For PLCs"
Once I select COM Port and hit next, it says "Modem port has been Selected. Do you wish to continue."
If I click yes
Same window popup again. I click on Yes.
Following errors coming up.
"Cannot transfer the Function Block definition because FB Source has been transferred to the PLC. Do you wish to continue?"
If I click yes.
coming up with transfer window but after few seconds got second error popup states that "Failed to upload the expansion functions"
If I click OK.
Third error popup "Failed to upload the settings".
If I click OK.
Finally got " Program upload from PLC NewPLC1"
Upload successful.
Once I hit OK. It says "Upload Successful"
I believe that I have given enough information.
Seeking a wise solution to overcome this issue, help me out.
I'm new to OMRON PLCs.
Regards
Lachuu
Hi all, I need some help in uploading of QuickPanel gp570-sc21 program to PC. I load from QP to PC the project through the working HMI-CAB-C49...
2,030
I have a machine that was powered off for repairs, when powered back on the Panelview fails to upload the tag database from the PLC. Its a...
1,545
I was onsite yesterday and had issues going online with a processor. I could see the PLC in Linx, I could go to the webpage in a browser, but in...
1,784
I am trying to upload program from 1769-L32C using RSlogix5000, Communication is established but when uploading it goes through these steps...
19
6,051
Hello all, I am trying to save a program from a HMI (GP577R-SC11) to QuickDesigner 3.70 and I get an error message at the VERY end saying it's...
4,721
