Urgent help needed
rajnayak
Mar 2017
India
Hello friend's
i need help to rectify below error in my machine can anyone advice me how to do it???
Error code list[Error code 4103]
Applicable machine Basic model QCPU, High Performance model QCPU, Redundant CPU
Universal model QCPU, L series CPU
Error code(SD0) 4103
Error message OPERATION ERROR
Common information(SD5-15) Program error location
Individual information(SD16-26) -
LED status(RUN) Off/On
LED status(ERROR) Flicker/On
PLC operating state Stop/Continue
* CPU operations when an error occurred can be determined with a parameter.
(LED indication varies according to the CPU module status.)
Diagnostics timing When instruction executed
Error description & cause
The configuration of the PID dedicated instruction is incorrect.
Corrective action
Read common information of the error using the programming tool to identify the numeric value (program error location).
Check the error step corresponding to the value, and correct it as necessary.
_----------------------------------------------------
Error code list[Error code 9000]
Applicable machine Basic model QCPU, High Performance model QCPU, Process CPU
Redundant CPU, Universal model QCPU, L series CPU
Error code(SD0) 9000
Error message F****
Individual information(SD16-26) Annunciator number
LED status(RUN) On
LED status(ERROR) On/Off
* For the Basic model QCPU, it can be turned on and off by the LED control function.
(For the High Performance model CPU, Process CPU, Redundant CPU, Universal model QCPU, and LCPU, it can only turned on.) The manual of the CPU module used (function explanation, program fundamentals)
LED status(USER LED) On
* The Basic model QCPU does not have the USER LED.
PLC operating state Continue
Annunciator (F) turned on.
(The "****" portion of the error message indicates an annunciator number.)
Corrective action
Read the individual information of the error using the programming tool to identify the numeric value (annunciator number).
Check the program corresponding to the value.
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
239
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
628
Hello guys, So I uploaded the .exob, decompiled and made some changes then compiled and uploaded the project only to realize the buttons and...
32
6,407
Hello everyone, I have an emerson Commander SK, 2.2 KW, 220 single phase drive that I'm having a problem with. So the drive was working fine and...
6,526
Hi Guys, I have a serious problem. Due to my own negligence and stupidity I damaged a MPL-4560F-M motor's encoder (SRM50-HFA0-K21). I bought a...
2,785
