Is the wiring different? all ouputs wired the same
Is the power supply the same? Same power supply
Are the LEDs the same brand, model, and size? all opperate at 2-3 V, I took a separate 24VDC source and all LEDs lit when I touched the wire to their path
Do you have the 3 unlighted LEDs turned the same way with power wire to + terminals, - power wire to - terminals?
I do not have 24VDC coming off the outputs. before O0:1 lit as per the original program. Now with new test program, only O0:0 lites as it should in first version, but O0:2 and O0:3 are ON at LEDs in the PLC unit indicators and Micro Logix ladder diagram but not on breadboard output LEDs after I edited the original program to include o0:2 and O0:3 turning on. I branched these two under O0:1 in the program. I used a switch for I1:3 to turn all of them ON.
I figure when the PLC LEDs go on, I should have 24V at the terminals to feed output
I have a 1 amp fuse before the PLC and before that I had .6 amp but blew them
thanks so much for your reply
