Uses of Alias Tag Types?
scarince
Jan 2009
Dayton, OH
152
I know there must be a basic answer to this, but could someone give me an example of how one might use an Alias tag type in practice?
I think I understand how they work, but I feel like maybe I'm missing something because I can't understand why one would ever use them?
Thanks!
Here is a reason to use an alias in its simplest form. Lets say I have a system with one input module. To address a push button that I have connected to the first input on that module in the program, I have to refer to it as "Local:1:I.Data.0". Every time I want to use that in a rung I have type that out. Yuuck. So lets create a bool tag that aliases that input point and name it "PB1". "PB1" is now an alias to "Local:1:I.Data.0". Now when I build a rung, I just type in PB1 where I want to use that input point. RSLogix5K now associates "PB1" with "Local:2:I.Data.0".
A nice feature to that example is that if I know what components are in a system, but the hardware design hasn't been finished, I can start the logic by creating simple un-aliased tags, such as "PB1", and when the design is complete I can edit those tag properties and assign them aliases to actual inputs - I don't have to edit the logic for the newly resolved addresses I was waiting on.
I create alias to match wire numbers on prints. So troubleshooting a tech can enter wire number to find program use.
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built...
235
Good Afternoon , I'm sure there are many Ishida Muti-Head Weigh Systems . We have a Ishida CCW-M-214W Multi-Head system . We are...
545
When i try to open the properties of a 753 drive, i get a fatal error and logix crashes. However, I can open the same AOP on V31 and it works...
790
Studio 5000 version 34. Have error on PIDE CVFaulted (Status1.2), Control variable (CV) health bad. No more information online or in...
974
Just wondering what other folks have used on their digital output loads when using this digital output module. There will be a number of...
1,077
