Valid node numbers are between 0 and -1
Harmony.hrc
Harmony
Both should be under RSCommon. If RSlinx has run, it will have generated those two files. If not, you may have to un and re install Linx.
they aren't in there but rslinx has run and regitered the slc fine...i'll uninstall and reinstall and see what happens, thanks
First pic shows rslinx connected
next 3 pics show me being forced to enter -1 into the node address and not being allowed to go online
does this have anything to do with me using a usb serial cable? Does the SLC 5/03 automatcially default to a different protocol or something? Despite the fact i can see in rslinx?
jimmy, go back and reread okiePC's post #14. See pictures below.
What you are trying to do in the doc you posted is useless and will not get you online.
Click on Who Active Go Online
Then Select processor then click Ok.
If you don't have a matching file you may be ask to upload.
I have no experience with the USB-485 converter you are using, did you install any required drivers that it needs?
Do you have a screenshot of RSLinx showing the PLC you are trying to connect with?
If you can see it in RSLinx, try going online like this and don't worry about the system preferences...
I cannot do who ctive go online in rslogix, when i try nothing happens, no error message nothing. The frustrationg thing is that i can do it in rslinx...
I'll repeat okiePC, screen-shot - show us what you see.
Lads,
When in RSLogix 500 I do the following:
Click on comms tab
Then click on 'who active go online'
and nothing happens, no error message, no box, nothing.
I re-installed RSLinx but still cannot find the harmony files mentioned in post 16...
downloaded rxlinx (non lite version) solved the problem....sorry for taing up som much of your time over something so small, i relly appeciate your help, cheers.
Hi, I'm trying to add ethernet modules to one of our plcs, but I get about 15 errors that say "Invalid Signature. Reseal instruction to resolve."...
323
Hello, Im new to Studio 5000 View Designer and i try to make a popup reusable screen. So i create a user-defined screen with 2...
250
I've got this start screen where the user has to enter their username and password. The username and password feature works fine. However, I want...
1,445
Hi, I'm setting up a new cell with a Fanuc R30iB and Compact Guardlogix 5380 PLC. I have gone through my robot setup as usual, but have not...
730
I activated the Studio 5000 license with the CodeMeter on a virtual machine. Unfortunately with the subscription license I was unable to create...
1,236
