Vijeo Designer Addressing
tomhelliwell
Feb 2008
Sheffield
25
Hi all, im have a problem trying to address my tags to the PLC. I'm using Vijeo Designer 4.6 and a Magelis XBTGT7340 on Ethernet.
In the variables list I have setup the tag to 'external' and 'XWAY' (configured to the PLCS ip address). The problem occurs when trying to fill in the address field, I can only choose the following types:
%MWi
%KWi
%Mi
%Si
The address im wanting to tag is %Q0.5.1 how do i get the HMI to read this output?
AFAIK you cant, you will have to map your Outputs to a %MW or similar and read the bits back in the HMI, for instance make %Q0.5.1 = %MW5.1 or %M1
What PLC are you using ?
The Vijeo Designer doesnot give you this ability...
Transfer Q0.X.Y to a certain MX (Ex MX15:=Q0.5.1) in the PLC program and make the tag for the MX in the Vijeo Designer
Good Day All I am in the process of creating a Vijeo Designer (Magelis HMI) replica of a Wonderware project for control out in the field. On the...
1,260
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
238
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
250
Since upgrading to V6.2 12.24 SP12 24-21 the M221 PLC is no longer recognised by the HMI. The screen still works but it does not talk with the...
1,056
I work for an OEM. I am trying to develop a generic HMI program that will display an overview screen displaying between 2 and 6 "widgets"...
1,384
