Vijeo Designer HMI link to BACNET protocol
vic_yubal
Aug 2011
Saudi Arabia
Masters,
I have Vijeo Designer v5.1 HMI which is to be link with the BMS using BACNET protocol. I am using the PROTOCON module(Protocol Converter)which converts MODBUS to BACNET. It is connected from PLC through Modbus Port using modbus cable and RS485 to BMS. Now, my problem is how to map the adresses from PLC to BMS System which is using BACNET protocol. Is someone have an Idea about this.
I am using MODICON PLC, part NO. 140CPU67160 redundant system and Magelis HMI XBTGT7340.
Dear All, Is it possible to replace a variables in vijeo desiger like other HMI software by find replace variables to save time. let's say that a...
19
21,090
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
194
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
192
Since upgrading to V6.2 12.24 SP12 24-21 the M221 PLC is no longer recognised by the HMI. The screen still works but it does not talk with the...
1,006
I work for an OEM. I am trying to develop a generic HMI program that will display an overview screen displaying between 2 and 6 "widgets"...
1,332
