Vijeo Designer Replacing Variables (Schneider HMI)
mar_13
May 2007
in Amman
Dear All,
Is it possible to replace a variables in vijeo desiger like other HMI software by find replace variables to save time.
let's say that a faceplate with following variable:
P1_RUN
P1_REMOTE
P1_FAULT
and I want to replace all with:
P2_RUN
P2_REMOTE
P2_FAULT
Is it possible
Regards,
Marwan
If you change the variable in the variable definition table then it is changed throughout the project.
A couple of thoughts, if you have multiple devices with similar setups (as in your example) then you can build a user defined type with all the elements (Run, Remote, Fault) and then just create instances of that type. Then just change the name of the tag P1 to P2 and all the references will be changed (to use in the project use the format P1.Run)
Another way to organise your tags is to use folders, ie create a P1 folder and put all the tags associated with P1 in that folder then you just change the folder name (same usage method as above eg P1.Run)
Thanks Geof :)
Could you please send me a document to show how to create instance.
I have the same face plate for 50 pumps and I don't want to animate each item inside each face plate 50 times.
Regards,
Marwan
I mean I want to copy a face plate of pump # 1 (Already animated for pump 1) then make it to pump # 2 without modifying each animation.
This feature is available in other HMI's software and SCADA software.
Regards,
Marwan
I have the same desire which is to take a simple grouped object that in my case uses three different variables, copy it, and paste it somewhere else on my screen and reassign a different set of variables. Surely there is a way to do this. I see some discussion in help about "reference" tags, but have not yet gotten my head wrapped around it. Has anyone solved this issue?
All my previous comments still stand. If you are using the latest version (6.2 thanks Chud) then search for placeholders. This will do exactly what you want
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
181
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
181
Since upgrading to V6.2 12.24 SP12 24-21 the M221 PLC is no longer recognised by the HMI. The screen still works but it does not talk with the...
998
I work for an OEM. I am trying to develop a generic HMI program that will display an overview screen displaying between 2 and 6 "widgets"...
1,311
Hey all, I am using Vijeo Designer v6.2.8.12 for a mineral plant project. For that, I needed to incorporate three different plants' HMI page in...
1,202
