That usually happens either due to memory overload. Are you logging data at a fast rate, are you running too many scripts, mathematical computations , FOR loops, large bitmaps, large arrays - basically memory hogging applications ?
During runtime go to configuration menu in your Magelis -> check memory usage .
Also, under the Vijeo help file look for "Project optimization".
Good luck !
