Voltage in New Zealand
Haem
Dec 2007
Haag
Hello!
Please, can anybody tell me what kind of voltage is used in new zealand in industrial environment.
I´d like to know for single and three phase system:voltage,frequency and grounding system.
Many thanks in advance!
cheers,
Haem
Hello!
cheers,
Haem
New Zealands voltage ranges are used both domestic or industrial
3 phase supply = 400volts 50 Hz.
Single phase is 230 volts
which is 400 v divided by square root of 3 as we use star (wye) point as Neutral.
Hello!
cheers,
Haem
I believe it is no different than what is now the European standard we just got it first.
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
142
I've got 6 identical regenerative vacuum blowers powered by 6 identical drives in 3 identical panels all fed from the same 1 main building feed...
27
891
Hi all, We are currently experiencing an DC over voltage fault on one of our inverters. During commissioning a snag was raised whereby excess...
204
I have a Siemens 1515 controller with the configuration of cards (input, output, safety input, safety input, safety output). I am having an issue...
185
Good Morning , I installed an AC Tech ESV 1 HP Drive on a small bucket conveyor. Before it had a DC Motor on it . It now has a Baldor 1 HP...
214
