VPN routers: e*W*o*n vs StrideLinx
Elcan
Apr 2008
NC
935
Hello all,
This topic was discussed as a secondary one in the link below, but I wanted to create a separate and updated thread:
http://www.plctalk.net/qanda/showthread.php?t=110408
I'm debating between using the proved e*W*o*n VPN routers my company has been using for a few years (we have over a dozen units in the field), and the new StrideLinx, that has the following advantages over the other one:
  • Cheaper
  • 5 GB free vs 1 GB free
  • Unlimited concurrent client connections vs 1
  • Unlimited mobile sessions vs 3
  • It has advanced rights management
I would like to hear from people already using the StrideLinx.
P.S.: remember to write "e*W*o*n", otherwise it will show up like ****
Thank you!
I only have two Stridelinx in the field, and one Co-sy. My comments in the other thread in your link pretty much cover my thoughts on them. They all work great, the Stride is a little bit simpler to set up and less expensive.
I'm curious as well. As for advanced right management, what's the level we are talking about?
For example, for two users, A and B, can I do this?
A: VNC to IP X and Y only.
B: VNC to IP Z and Etherent/IP to X and Y.
Thank you, OkiePC.
I've used quite a few Cosy 131 and a few Flexy so I'm interested in reviews on the StrideLinx as well.
E w 0 n has a version of eCatcher for mobile platforms. This allows you to create a VPN to your mobile device. I find this works very well for some of the HMI vendors like C-More whose remote apps aren't browser based.
Does Stride Linx have any similar capability?
Over the last several years we've setup 25 or so VPNs at customer locations. Initially we used a Netopia ENT-3386 router as a PPTP endpoint and...
4,240
I am trying to use setup a remote vpn router for external OEM connection. The thing I cannot wrap my head around is the gateway. We use the...
277
Have anyone done this? I don't see why this wouldn't work but I may be missing something too. Getting any recurring account opened is a pain...
1,062
Hello all. When I try to connect to a S7-1200 PLC (Tia Portal v17) which has a CP 1243-1 module that is connected to my clients network I get...
1,517
Hi, We are trying to access a remote PLC for debug, the PLC is networked in with a PC that we can access through TeamViewer. Is there a way we...
2,058
