VPN Setup
solehm
Jan 2006
ca
I have absolutely no experience with setting up a VPN. What software/hardware is needed to set up a VPN? Do I need to have a static Internet IP address or is dynamic Internet IP ok?
I came across a Linksys VPN router after a few searches. It seems these routers have VPN software built into them and as long as a computer/laptop has Windows XP or 2000, they can connect from a remote site.
Has anyone set up VPN using Linksys Routers (RV082, RV016, etc.) before? If yes, how difficult was it to set up? Linksys also have something called QuickVPN. Is that any good?
What other manufacture has something similar?
Thanks in advance.
P.S. Accidently post question on the practice section.
If you search this site for VPN you will see a number of threads that may help you while waiting for others to reply.
Hope this help,
Bob O
I am trying to use setup a remote vpn router for external OEM connection. The thing I cannot wrap my head around is the gateway. We use the...
278
I've seen some discussions about VPN in this forum. Unfortunately, I know nothing about setting up a VPN. For an existing plant, I need to...
2,711
Have anyone done this? I don't see why this wouldn't work but I may be missing something too. Getting any recurring account opened is a pain...
1,066
Hello all. When I try to connect to a S7-1200 PLC (Tia Portal v17) which has a CP 1243-1 module that is connected to my clients network I get...
1,523
Hi, We are trying to access a remote PLC for debug, the PLC is networked in with a PC that we can access through TeamViewer. Is there a way we...
2,062
