What is Kepware and why would you use it?
"TOP Server" is also out there as a choice for an "OPC / IO Sever". As I understand...It uses KepServerEX (developed and sold by Kepware)....it is just rebranded.
"Top Server" is sold by "Software Toolbox"
http://www.softwaretoolbox.com/hmiscadaaddins.html
"Software Toolbox" also has some really nice add-in apps for most HMI/Scada software systems.
What they have for Wonderware is really nice. They just released the software that performs queries on the *.LGH history files.
Hey, i actually now using kepware. I wanna read and write data from omron PLC using serial communication to siemens PLC using kepware. But, the serial communication is converted using serial to ethernet converter. I dont know what kind of communication driver should i use in kepware. Have anyone done it before?
Your post is not really that clear, first of all, I assume if using Kepware you have a PC running this, is it serial to ethernet or ethernet to serial. for example you can encapsulate the 232 in the ethernet then send it to a ethernet to serial converter. you mention send data to Siemens, not sure if Kepware can pass data between PLC's my version is a little old normally, you have some form of client to manipulate the data.
however, assume you are reading data from an Omron via 232 through a 232 to Ethernet serial server then you can encapsulate it within Ethernet see picture.
I do suggest you post your question as a new post not an old one like this.
Yes i have PC running. It is serial to ethernet. I havent tried to send data to siemens tho. My concern now is reading data from the omron. I actually read the data from an omron rs485 to ethernet serial server. Yes i should have. Thankyou for your kind replay. I'll try to encapsulate it
I have a strange Kepware issue I have been dealing with for a few weeks. I have Kepware setup with the Omron NJ Ethernet driver and reading in...
107
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
171
Im trying to get data from AB guardlogix controller using Kepware in a remote location but it seems that version 6 can only support contrologix...
451
Hi, Have anyone came across issue with Kepware or Linkmaster not returning correct values (Unknown Quality) for some tags From OPC DA Client...
691
I’m attempting to configure KEPWare to poll a Modbus device via Modbus TCP/IP. However, everything I’ve tried results in an error being reported...
426
