Win CC Flex 2008
JCreel
Apr 2020
Mississippi
51
Hello All,
I have a Windows XP machine running win cc flex 2008 for siemens HMIs and when i open an existing program nothing appears in the software. None of the normal interfaces appear to come up to make modifications or just being able to download a pre-existing program into an HMI. When i close the program and restart and try to open the same file it says that that file is already in use somewhere else.
Note: Not all that familiar with this software and very limited on knowledge so any insight would be appreciated.
Thats.... really wierd. I'd recommend calling tech support (if they even still support Flex? I dunno)
Can you create a new project? It might be worth uninstalling/reinstalling Flex, to see if there was some kind of bad install messing things up.
No it will not let me create a new project. This didnt start happening until after i removed the HDD from the computer. We were trying to run this on a new machine and when we put the HDD back in, this is the only application that will not run correctly
I know this is a long shot but here goes..... I am trying to import a Protool project using an old laptop with WinCC Flexible 2008 SP1. in doing...
3,004
hello. how I do capture dial, alarm screens win 6 cc, which is in a profinet network because I have to check every alarm and can not stand...
1,493
Hello i have a problem how can i modificate the op 277 with wincc siemens, i need modificate and put name buttom k1 the program dont allow me...
1,850
Hi all, Today I had a problem with installing WinCC Flexible 2008 on a Windows XP SP3 machine. Office was installed on that machine. Problem...
5,374
I just upgraded an old protool app from an OP37 to an MP277 with WinCC Flex. I am not a siemens guy. The conversion seemed to go fine with a...
22
6,196
