Win CC Flex Faceplate
lucifer
Nov 2003
52
Friends,
I am using Win CC Flex V1.0.0.0. It's running on HP Compaq , 512 MB, P4 3 GB and it's unbelievingly slow....but that's different matter..I see people have already talked on this and even 2 GB mem can not satisfy Flex.
I am finding it difficult to use the faceplate in Wincc Flex. It will be great if anybody could spare some time and explain it.
Thanks.
You could upgrade to WinCC flex 2005 and load the hotfix3. It doesn't make a huge difference in speed but does have some extra features.
What do you mean by faceplate?
Well, thanks for that advice.
And regarding Faceplates, I mean exactly what it sounds. Faceplates....used in all SCADA and DCS for PID, Motor and Valve blocks. There is a tab named Faceplate in Win CC Flex, has anybody used it?
Regards.
First, you must absolutely upgrade Win CC Flex.
The initial version was not only slow, but also very unstable.
The latest Win CC Flex 2005 is faster (*) and quite stable.
Second, Faceplates is a way to make reusable objects.
You create graphics and animations, and link these to tag placeholders.
Unfortunately, it is not all graphic objects that can be animated, the basic types lines, circles etc. cannot.
So at present it is best used for objects using buttons and i/o fields, PID or Motor faceplates f.ex.
The functionality should be expanded with coming versions of Win CC Flex, so all kind of reusable objects should be possible.
*: Even though the latest version is relatively faster than the previous versions, it is still slow and resource hungry when compared with "normal" programs.
Expect to use a fast PC with at least 1GB mem (2GB is better if you open two instances of Win CC Flex at the same time).
Hello All, I have a Windows XP machine running win cc flex 2008 for siemens HMIs and when i open an existing program nothing appears in the...
2,479
I know this is a long shot but here goes..... I am trying to import a Protool project using an old laptop with WinCC Flexible 2008 SP1. in doing...
3,024
hello. how I do capture dial, alarm screens win 6 cc, which is in a profinet network because I have to check every alarm and can not stand...
1,496
Hello i have a problem how can i modificate the op 277 with wincc siemens, i need modificate and put name buttom k1 the program dont allow me...
1,853
Hi all, Today I had a problem with installing WinCC Flexible 2008 on a Windows XP SP3 machine. Office was installed on that machine. Problem...
5,376
