Wireless Modbus
Homer_BL
Feb 2003
252
Hello!
Suppose that I must realise wired Modbus RTU communication between AB and Siemens PLCs. It should be like this (A).
Has anyone did it? Any comments? Should it work? Any suggestions regarding communication settings?
Now, if it can work, suppopse I must convert it to a wireless solution (B).
Thanks and best regards.
Hello Homer;
We have done something of the same, a few years ago, using Data-Link equipment (they have radio links both for Siemens and for Rockwell). Comms were slow, but eventually steady.
http://www.data-linc.com/pdffiles/siemdoc.pdf
So if your equipment is industrial-grade and you are a bit familiar with it it should work.
If I remember correctly, the most important thing to make sure of was using the confirmation bits on the Siemens FCs to certify that the transmission was recieved correctly by the first slave before stepping to the next slave.
Hope this helps,
Daniel Chartier
Hope this helps,
Daniel Chartier
Thanks! :)
I have Siemens Modbus master and slave drivers, literature, sample code etc..., dowloaded from Siemens site. I believe that wired solution will work (this we can do when all cabinets are ready, in our workshop - we will simply connect ports and I believe it will be OK).
What I am affraid of, are modems and communication between CP341 and proper modem, and how to diagnose possible problems (I suspect that network timing will cause problems).
Thanks for You help again, it's easier for me knowing somebody did it before.
9600kbit/s are good enough for me, just need to work. :)
Best regards,
Homer_BL
i have three devices which is having modbus communication. i want to take these three device in a wireless network... and then i will connect this...
1,372
Hi I am new to programming and would like to know what i need to do to intergrate a rosemount wireless gateway into a modicon quantum plc via...
1,931
Hi Guys, need your advise here... I wanna communicate CLX to a DCS Modbus TCP/IP here's the configuration: MVI56-WA-PWP ---wireless--- >...
3,389
Wanting to go wireless with some of our modicon PLCs and link them to our Modbus+ network. I found this apparently soon to be available. Anybody...
2,424
Hello Y'all, I was wondering if there is any standalone solution to replace the ethernet cable to connect to a PLC? like perhaps a "Dongle"...
26
2,368
