Wireless system to transfer state of switch/sensor
infrared
Oct 2009
outback
looking for small wireless system to transfer the state
of a switch to a box 200m away.
I have a switch sensor, which can be on or off,
the status of this switch needs to be known on a system 100m away,
as if the switch was there.
I dont want to transmit data, just the state of the switch.
Who makes this kind of equipment ?
The State of the switch is data, eventhough it is one bit !
For wireless you have to go for a radio transmission system, or GSM/GPRS system. Checkout RadioLinx products from Prosoft Technologies for Radio communication interfaces. For GSM/GPRS , checkout the RTU products from any PLC vendor ( everybody has RTU with GSM/GPRS communication )
thank you
Thanks,
Surecross from Banner has a solution,
it sends a discrete or analog I/O from one little unit to another.
I also found another in the meantime, Jay Electronique, ( ISIS series)
that does similar thing.
You wire discrete signals in at the TX unit, and get them out from the RX unit. A small unit with 4 inputs/outputs.
Most radio/wireless solutions are really designed around PLC interfaces with their protocols, much too fancy for my application.
Thank you everyone !
Thank you for these referals, this is a great help.
I have studied some products and are comparing them.
Hello again PLC Gurus got another question,my latest job was a simple one, it was a manual conveyor and turn head setup converted to plc control...
2,346
I've looked around for something like this but haven't found much. I was hoping someone here had seen/heard of something like what I need...
2,560
Hi everyone. Happy New Year. I'm a newbie to this forum as well as to AB. I'm working on a Half Duplex DF1 wireless system that uses 3 AB...
10,280
Hello ! I used to have a wireless access point that I could plug into a PLC network and set it with an IP address that fit onto my networks...
105
Hello Y'all, I was wondering if there is any standalone solution to replace the ethernet cable to connect to a PLC? like perhaps a "Dongle"...
26
2,395
