Thank you all for the reply.
Still is unclear for me how to do the Fault Reset with the Red Lion, my inverters are Yaskawa models V1000 and J1000.
Wolverine said to use the Bit 40002.3, I cant find that number on the list of parameters on the Red Lion, the closer one is the DA4 400000 to 465535 at least is the DA4 400002 and the bit is the 3, is that what you mean?.Thanks.
Where I can find a list of the meaning for all the register appears on the Red Lion like:
DA0 Modbus Output from 000000 to 065535
DA1 Modbus Inputs from 100000 to 165535
DA3 Modbus Analog Register from 300000 to 365535
DA4 Modbus Holding Registers from 400000 to 465535
There is more Register but probably this ones are the ones related for what I'm trying to do.
The others parameters values as A,B,C,D,E,F,H,L,N,O,Q,T and u are ok, not a problem with those ones are very clear, the others DA are the ones I'm in trouble to understand the meaning, do you know where I can find a list or link where I can read more about it?.
Your comment are very welcome and again thank you very much for your help.
Thanks,
jpoyatos
