Wonderware Playsound() Freeze the screen
nyan00122
Mar 2015
marikina
need help Playsound() command freeze during runtime.
Or is there any alternative solution to play sound from a player like Windows media player or VLC? need a script sample. Thanks!
First check what version of the software you have and if there are any patches to apply.
https://wonderwarepacwest.com/uploads/2014/02/WW-InTouchHMI2012R2-P01-EN.html
The command should not freeze during the run time. I would notify WW of this issue if it continues after applying any relevant patches.
Here are a couple of links associated to the PlaySound command:
http://www.plctalk.net/qanda/showthread.php?t=63728
http://www.plctalk.net/qanda/showthread.php?t=49018
Hope this helps you out.
Regards,
Hello, Im trying to modify the script for our alarm playsound file to only play when priority of an alarm is 1-3 and not whent he priority is 4...
5,389
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
172
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
112
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
197
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
191
