Generic Ethernet Module for a D-MAXE 2 controller
kpElec
Oct 2016
Minnesota
23
Hi all,
I am installing a copy cat program for another system that is using a D-MAXE 2 controller.
The previous program worked well. I was able to use BootP to set the IP address of the D-MAXE 2 controller that seemed to be successful. I was able to ping it for a good response.
However, the generic module is showing a fault. The one thing I did different was to change the previous IP address from 192.168.1.121 to 192.168.1.225 in the generic ethernet module.
I can't even see the D-MAX in RsLinx but I can ping it just fine.
I attached my configuration.
Does anyone have any ideas?
Get an IP diagnostic tool like Angry IP Scanner or TCPING that will let you check the connectivity to the device with a TCP Port number instead of just an ordinary ICMP Ping.
It looks like D-MAX web controllers support both Modbus/TCP and EtherNet/IP. It's possible that you have the Modbus protocol enabled but not the EtherNet/IP protocol, or that the address configured by BOOTP didn't survive a power cycle and you're seeing a different device with PING.
Modbus/TCP uses TCP Port 502. EtherNet/IP uses TCP Port 44818.
Most EtherNet/IP devices will show in an RSLinx browse. I don't know for sure if responding to the List Identity command is required for EtherNet/IP conformance testing, but nearly every device I've seen that supports EtherNet/IP does so.
Hello, We are having trouble setting up a generic ethernet module for a Yaskawa GA80U4168 drive in RSLogix 5000 Version 20.01. All of the...
609
Hello all, I need to add a module in logix for an SMC pneumatic valve manifold specifically EX600-SEN3/4. The eds files I add crash the program...
677
So Rockwell PLCs have some generic ethernet module options available in the IO tree configuration. With the standard generic ethernet module, you...
730
​Hello everyone, I triyng to link a Power Module eMB-60R from Robot Adept Viper s650 to CompactLogix, version 19.11 I followed exactly the...
2,650
Hello: I have not been able to get RSLogix 5000 to display expected configuration screen for 1732E configurable armour blocks. Waiting for RA...
39
12,411
