EtherCAT segment length
CX_Luigi
Sep 2010
Hong Kong
20
I am designing a system with a fair number of basic input and output cards spread over a large area, so am foreseeing decentralized stations. From master to stations, medium length is around 150 meters, with longest one just over 200 meters. Can EtherCAT use repeaters/switches to extend segment length?
I have an Omron NX PLC NX1p2 which Supports EtherCAT . also I have Balluff BNI00HA Ecat Block(IOlink Master). I have setup communications and...
175
If an IPC with Codesys runtime on it has two separate ethernet ports, is it possible to have an Ethercat master on each of them? I do not find...
552
Hello everybody. I encountered a problem - I don’t know how to update the firmware on the Mitsu MR-J5-40G-N1 (ethercat) servo amplifier. My...
422
Just curious if anyone has been down this road before? Considered using one of the anybus gateway adapters, experience with them. Master...
684
Afternoon all, So, i have an output that is being fired from 2 inputs separately. 1st input is a sensor, when something passes by it should...
332
