Generic Ethernet settings for Bizerba scales
kennyg70663
Dec 2022
Massachusetts
Trying to connect 5069-L310ER controller to a variety of Bizerba scales. We currently connect via TCP/IP connection from a business system but we need to change to Rockwell PLC. We have a working example with a Siemens but I can't get the Rockwell generic Ethernet Module to successfully connect.
I can't find where Bizerba publish Assembly instance or size information, but we know the size of the packet from the Siemens example.
TIA
Welcome to the PLCTalk forum community !
I haven't used Bizerba scales before. What exact models do you have in your facility, and can you point to the Ethernet specifications ?
Some industrial weighing companies do have Rockwell-specific interfaces; Rice Lake, Hardy, and Mettler-Toledo come to mind.
But Bizerba probably doesn't have an EtherNet/IP cyclic I/O Adapter object in their interface, which is what would be required to use the "Generic Ethernet Module" object.
I dislike that name; it's "Generic" only to the extent that it's a Rockwell-compatible function with a blob of undifferentiated data. It's not really "generic ethernet".
The good news is that you've got a 5069 series controller, which supports "Raw Sockets" and can send non-Rockwell-Automation messages over TCP/IP and UDP. That may be where you can re-use some of the information you have from the Siemens example, though that might be a ProfiNet generic object since they're a German company and appear to have classic Profibus interfaces too.
Post as much info and links as you can.
And again, welcome to the Forum !
I know, there's tons of resources out there on how to setup generic ethernet devices but I just cannot figure this out, I'm not sure what I'm...
449
Hello, We are having trouble setting up a generic ethernet module for a Yaskawa GA80U4168 drive in RSLogix 5000 Version 20.01. All of the...
609
Do you have a recommendation for a low count IO system that you would stand behind for a remote site? It 1.5 hours drive time to the site. I...
957
Hello all, I need to add a module in logix for an SMC pneumatic valve manifold specifically EX600-SEN3/4. The eds files I add crash the program...
678
So Rockwell PLCs have some generic ethernet module options available in the IO tree configuration. With the standard generic ethernet module, you...
730
