1756-HSC Wiring
Greg Dake
Jun 2005
Milwaukee, Wi
550
Greetings,
I have attached a screenshot of something that isn't clear to me. Do Pins 35 and 36 get power from a separate supply? It doesn't say anywhere in the book..There isn't 24V across either of these two pins and common. I need power for my encoder, I'm assuming I supply power to pins 35 and 36, but will wait for a response just in case...
TIA,
Greg
IIRC pins 35 & 36 are the power connections for the outputs.
They are not needed for an encoder input.
I have am trying to determine if I can use a 1756-IB16I (or some dc input equivalent) to handle a 24vdc input pulse frequency of 80 pulses per...
946
Just finished an upgrade from a SLC500 to CLX where they had a 1746-HSCE and we're now using a 1756-HSC. Two wire pulse signal from the...
1,305
I have an older SLC500 that has a PLS card in its rack. I want to remove the SLC and add a L23E-QBFC1. Can a resolver be wired up to the High...
1,691
Our ABB Vision System requires a Pulse Train Input from an Encoder (12-15 VDC)to calculate the speed of the web. Instead of adding an encoder to...
1,574
I am upgrading HSC modules and have some questions. I can't attach the manuals for reference as they are too large. 1746-HSCE uses M0:e.1/4 for a...
1,657
