1769-HSC compact logix Single Ended Encoder not counting
antsrealm
Dec 2010
Brisbane
207
This is the first time I have setup a single ended encoder on a compact logix PLC. I wired in the pull up resistors and can see the A and B pulses flashing on the LED's and showing in the tags for inputstate A1 and B1.
However I can't get anything from the Ctr0CurrentCount it is constantly reading 0 despite the A1 and B1 input states changing from 1 and 0.
Last time I played with a rotary encoder was on a slc500 and didnt have half the tags this one does. What am I missing ??
Thanks.
Tony.
In the past with RSlogix 500 I had used a scale with parameters instruction to scale the number of counts to represent a measurement in mm.
What is the best way of doing that in rslogix 5000 ?
Hello all. I am having trouble setting up my HSC to count pulses from a prox switch. I have it wired to the prox and I see the .InputStateA0...
1,378
Here is my hail Mary pass I have a wheel that produces 33 pulses per revolution. The RPM of that wheel will be anywhere from 25.21 to 62.7 Pulses...
4,711
Hello all. I have an issue that keeps plaguing me. The system has a 1769-L24ER processor and a 1769 HSC card. I am using CH.0 for tracking...
1,474
Hello, Im trying to use a 1769 HSC card to get the RPM of a single channel encoder at 60ppr. Ive read the other threads of people have similar...
1,700
Flashing Red OK Status indicator : Rockwell Automation Publication 1769-UM006E-EN-P - July 2013 Table 23 - Configuration Error Codes pg 117...
2,187
