24 vdc portable power supply
dploof23
Jan 2010
Massachusetts
505
Hello all,
I am looking for a portable, (battery powered), 24 vdc power supply.
My situation is this....
I have a flow sensor that I would like to use as a portable diagnostic tool. I would like not to have to provide 120 vac to the unit. It requires 24 vdc at 100ma. I have a couple sensor testers here but they all use two 9 volt batteries and the output voltage is not enough. Is there a pre-canned solution for this out there or am I making my own? I did some searching and came up empty.
Thanks for any help,
Dave
What are your supply voltage permissible ranges? 3 9V batteries in series is 27V.If you must drop it closer to 24VDC exactly, you could put in a series 3V zener, or 4 series 1N4004 diodes.
Lithium will be best. They hold voltage till end of charge, then drop rapidly.
Lithium 18650 = 3.7V
7 x 3.7VDC = 25.9 VDC
Multi-Cell Lithium battery holders are all over.
I do rdrast's thing, three series wired 9V batteries for powering loop powered transmitters that typically can handle power supply voltages from 14-35Vdc when I need to ensure the unit is getting clean, isolated DC power.
I've run a radar level transmitter for four days continuous at 18mA output with a battery pack.
Extrapolating for 100mA output, a 9V battery pack will probably last almost a day of continuous output.
It's cheap and easy to make - Radio Shack sells (or used to sell) the 9V battery.
I use a coaxial DC power connector jack on the battery pack and a mating plug on a separate cable with flying leads. I keep the flying leads cable off the battery pack during storage or movement to ensure that leads to the battery pack don't short because those 9V batteries produce enough current to burn the insulation off the wires and start a fire in the event of a short.
Permissible input voltage is up to 30 volts dc. I think I am liking NetNathan's suggestion of a multi-cell lithium setup. I hadn't considered that but it makes perfect sense.
Thanks for all of the replies.
Dave
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
439
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
122
I have a conundrum with this current circuit. I have a Siemens 1215C AC/DC/Relay and an old drive - Ratiotrol (now Boston Gear company I...
1,193
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted...
17
4,177
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,660
