A Free HMI with Eye Catching Graphics is Now Available
Which version of VB did you create this with? I currently have 2010, and it wont open.
I use Visual Studio 2015 Community Edition. It should open with 2010, but you would need to install the service pack:
https://www.microsoft.com/en-us/download/details.aspx?id=23691
This is actually going to be the last version of AdvancedHMI that will guarantee support for 2010, so I have been recommending to everyone to upgrade to VS2015:
https://www.visualstudio.com/en-us/products/visual-studio-community-vs.aspx
Love-love-love this HMI! I am a little stuck on something though. I have an Omron NJ101-9000, using FINS with Sysmac Studio and all is well except I can't figure out how to get my strings from the Omron to display on the HMI. It produces a numeric value as opposed to text. Within a couple minutes I was controlling the Omron NJ with your HMI. Really nice. Thank you Archie. 🍺
The Omron drivers do not support string directly, but I'm sure I can come up with some way to read it as integers, then convert it to strings.
I've never used the NJ controller, does it support a string data table or is it stored in something like a "D" data table?
That is what I am trying to ascertain as I write. I am trying to use a "D" data table however, it may not be the correct way to do it, and that is why I am getting numeric values and nothing alpha.
You will need to convert the integers to a string. Here is a function that will convert the values into a string:
Code:
    Private Function ConvertIntsToString(ByVal ints() As String) As String
        '* Convert values to an array of bytes
        Dim ByteArray(ints.Length * 2 - 1) As Byte
        For i = 0 To ints.Length - 1
            '* Upper byte
            ByteArray(i * 2) = CByte((CInt(ints(i)) >> 8) And 255)
            '* Lower byte
            ByteArray(i * 2 + 1) = CByte(CInt(ints(i)) And 8)
        Next
        '* Convert the array of bytes to a string
        Dim result As String
        result = System.Text.Encoding.UTF8.GetString(byteArray)
        Return result
    End Function
Try this to test it out:
- Add a Button to your form from the All Windows Forms group
- Double Click the button to get back to the code
- Enter this code:
Code:
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim values() As String = OmronEthernetFINSCom1.Read("D0", 10)
        Button1.Text = ConvertIntsToString(values)
    End Sub
Below that copy and paste the function from above.
Run the app and click the button to see if the text changes.
If I right click the MainForm and View Code, this is what I see:
Code:
    End Sub
            '* Upper byte
            '* Lower byte
        Next
        Return result
    End Function
Honestly excellent program has provided a lot of effort and time has been linked to the program b plc Dalta
I want a bundle plc LS XGB
Have a GE IC200CPU002 running a alarm monitoring program All of them are inputs except for the alarm sounder Looking for a free HMI which would...
814
The C-More remote HMI app on APP Store, Google Play and Amazon is now available free. The nominal charge has now been removed...
2,365
Hi I have a phoenix contact installation and I'm looking for hmi software to manage my project better. It has to be as cheap as possible, free if...
2,481
My brother recently bought a KEP HMI for a small project, he asked me to check out the software which is called EasyBuilder 8000...
3,717
Hello, i have a data historian system it is a GE proficy historian. i need an application that can be used to display the data in a HMI format. i...
25
9,535
