Analog input/output ideas for SLC 500
http://www.plctalk.net/qanda/showthread.php?p=14314&postcount=3
this should get you going ... when you calculate the needed resistance, don't forget that the input module will add 250 ohms to the circuit ... if you've got a 24VDC power supply, you can skip the batteries ... and the SLC-500 power supply probably has a set of 24VDC terminals built in ...
note that some Radio Shack pots that are marked 5K might be at the high or low end of the tolerance range - so you might not be able to go all the way from 4 to 20 milliamps ... but you still should get enough of a range to make for some interesting experiments ...
if you skip the box and the batteries, then less than $5 or $6 bucks should put you into the "analog input" game ...
Thanks for the help!!
Thanks again for the help. I hope once I get the parts hooked up I'll be able to figure out the scaling end of the deal.
Thanks John
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,417
Hello, I have a small programming task that I need help solving. I have to: * Create an analog input (4-20v)and a digital output * The analog...
45
25,134
Hey guys, running into issues trying to get some analog input and output cards for customers needing a few points here and there. with that in...
4,911
Hi; I need to monitor and log the 3phase AC input voltage for which I need a device to convert AC input voltage (say 350 - 440V) to analog (0-10v...
1,374
Greetings, I have been charged with a project to link data from a Beckhoff PLC using Allen Bradley Point IO to a PLC 5. The PLC5 does not have...
4,026
