Applications with HSCE2
ralfhfellipe
Jun 2009
minas
hello people
Again using the help of all. I have an application with the card HSCE2 class 4, configured for mode 4, and I'm using an inductive sensor on channel A. The reading is being done correctly, but at times need zero reading done by I2.3 (in slot 02). Is there any way to perform the reset of the reading of it? The configuration is as follows:
Not quite enough information...or too much.
Either way, this is a programming and engineering task, to be sure.
Now, with the 1769-HSCE, you can use different counters (I think there are 12), and some of the extra counters can be reset, unlike the main counter. (From memory here...)
thanks jdbrandt,
so, I did a program with a Preset Mode Programming (soft preset only). So as my card is in slot 02, the idea is every time it is necessary to reset the counter 01, send a pulse to the output O: 2/17, as well as the value of my presset this zero will automatically reset this counter. The big question will be whether it will work or not, notice if there is something new for now thanks for listening.:unsure:
Hi, I am having trouble with the comms within FT view SE v11 (premanent license). I created an HMI program a while back which was working just...
935
Good Morning , I've been using FactoryTalk View Studio from time to time , but I really don't understand all the options in FactoryTalk View...
1,173
I apologize in advance for my ignorance. I am supposed to program a vfd for New Zealand at 50hz. Any info would be appreciated. That is the only...
2,580
Has any come across a decent Industrial-Rated Cable Modem used for internet (Docsis 3.x) that they are using in their control panels? I've talked...
816
I used “Apllication Manager” and “Distributed Application Manager”,BUT it didn't work!And my FactoryTalkView Studio sever with “neteork...
6,297
