Then there is the "simpler" kind of multiplexing.
You simply setup a tag, and in the address specification you may write for example
DB[MultiPlexControlTag1] DBW2
DB10 DBW[MultiPlexControlTag2]
DB[MultiPlexControlTag1] DBW[MultiPlexControlTag2]
This does not eat tags, but you should manually put limits on the control tags so that you do not try to access outside what actually is addressable.
I use this some times.
