bar code scanner laser sensor
mpiotro
Aug 2004
Toronto
57
Hi folks,
Does such a thing exist? I have an application where I'd like to place a sensor conveniently close to a label that is to be scanned. (Actually, near 4 labels, as there are 4 components to a product, and the process step is to verify that the 4 components are properly cross-referenced to the panel). Ideally, I'd use the laser from the bar code scanner to tell the controller which of the 4 cards it is scanning.
I had a sensor rep in, and we tried to simulate it with his laser sensors (by covering the emitter and "scanning" the receiver but with no luck.
Am I asking for too much?
Have a great weekend everyone,
Mike
Panic,
Thanks for the link. I looked at the stuff (nice), but this wasn't exactly what I had in mind. What I'm looking for is a sensor that would get triggered by being hit by the laser of a typical hand held bar code scanner (probably didn't explain myself well in the original post).
I'm thinking even if it does exist, it ain't gonna be cheap.....
-Mike
Hello Guys, I am trying to add a Zebra DS457 FIXED MOUNT IMAGER with MICROLOGIX 1500 LRP 1. How to connect the imager with the ML1500 since it...
1,282
Hello Guys, I am a beginner in PLC programming. I am trying to add a Zebra DS457 FIXED MOUNT IMAGER with MICROLOGIX 1500 LRP to successfully...
1,190
I currently have a Red Lion G310 HMI and have a Unitech bar code scanner hooked to it through the USB host port B on the HMI. It works fine when...
3,216
I'm having troubles connecting to a honeywell xenon 1902 bar code scanner to my slc5/03 plc. I'm using an rs232 cable going to the channel 0 port...
22
9,478
Hello! I am working on a production line project and need a way to interface a usb bar code scanner (Symbol) to a Red Lion PTV using Crimson 3...
2,848
