bonding systems
randy
Supporting Member
Apr 2002
158
To the Electrical Engineers,
This topic has nothing to do with PLC’s, but I need some electrical professional help with this safety issue.
I am a Process Control Technician and I have recently started working for a food flavor and seasoning company. This company this located in the Cincinnati area. In one of there processes they are using 190 proof Ethyl Alcohol, which fall into Class 1 Group D of the NEC. I noticed that there were NO bonding strap being used on the equipment. I also noticed that when they fill the 300-gallon mixing tanks from 50 gallon barrels of alcohol, lifted with the forklift, they are bonding the barrel to the forklift. How would this prevent electrostatic form traveling or jumping arc? I though you were suppose to use earth ground.
Randy
Randy
My advice to you get good safety counselor to examine the process
and give you his opinion.
Any thing we would say might be not responsible.with out examine the process.
take care
Hi all, Hoping some of you have some recommendations for an all in 1 tester, the most well known brand here is megger so 1 by those would be great...
1,812
I'm doing some work preparing for adding some concrete patios. Im running conduit underground in preperation of a future garage. I'm also going...
30
11,353
Could someone confirm this please. If I need to use a 600 to 240 step down transformer i need to bond leg 2 and leg 3 to ground correct? See...
5,497
Wow, did you see the terrible accident in Seattle: http://www.bloomberg.com/apps/news?pid=20601087&sid=argFhVY_qDA8&refer=home I'll bet I'm...
1,720
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
113
