Equipotential Bonding
Drippin
Jun 2007
Cambridge
Wow, did you see the terrible accident in Seattle:
http://www.bloomberg.com/apps/news?pid=20601087&sid=argFhVY_qDA8&refer=home
I'll bet I'm not the only process electrician that has been tasked with checking/replacing bonding straps in a dries plant today!
Does anybody else have experience of ATEX rated areas? Currently we have no offical rating displayed in the area concerned. The management are thinking about banning mobile phones in the area (probably a good idea) but then we still alow electric fork lift trucks and normal BS1361 socket outlets in there - madness!
Oh well............
Hi all. I have never given grounding much thought, apart from that there must be a "good" grounding covering the entire plant. I though that a...
4,904
Hi all, Hoping some of you have some recommendations for an all in 1 tester, the most well known brand here is megger so 1 by those would be great...
1,812
I'm doing some work preparing for adding some concrete patios. Im running conduit underground in preperation of a future garage. I'm also going...
30
11,353
Could someone confirm this please. If I need to use a 600 to 240 step down transformer i need to bond leg 2 and leg 3 to ground correct? See...
5,497
To the Electrical Engineers, This topic has nothing to do with PLC’s, but I need some electrical professional help with this safety issue. I...
1,817
