Card access for PLC and Line Production
kdla
Nov 2013
Bradford, Ontario
I've read that I can use door access prox cards to override. Our maintenance manager wants to do way more and this is the only place I could find to get a definitive yes or no on what is possible.
I am I.T. support and do not have a PLC background, so be gentle with me.:D
1) card level access to the PLC - different access rights based on maintenance sub department (Operator, electrician, production engineer...) I would assume that this is done at the GUI Touch screen. Is this possible?
2) Card reader at each station on a line - most likely connected to an Epicor MES system. Is this also possible?
Regards,
Kerry
Dear All, If you could please help me with the following issue it would be very helpful. Trying to solve this for the last week. I've a L33ERM...
1,251
Hello! I am working on a Controllogix project with redundant PLCs. The primary and secondary racks both contain: [0]L71 [1]EN2T [2]CN2R [3]CN2R...
1,822
Hi I am new to Omron PLC. I am using CJ2M-CPU33 PLC with a CF card. Communication is via ethernet with IP address 192.168.250.2 (PLC). When I...
3,253
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
88
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
128
