Changing deveice from MP277 to Comfort panel
eibe
Jan 2012
Bergen
22
Hello.
I'm going to change my HMI's from MP277 to TP1200 Comfort. This was easily done in TIA, but obviously, as the resolution is much higher on the comfort panel, my old MP277 screens doesn't fit very well.
Is there an "easy" way to change text fonts etc on more than one object at the time, "fit screens" or other tricks that can be useful when changing the device as in my case?
In WinCC Flexible there is an option to either fit the objects to the screen size, or keep the existing sizes. Something similar must be be possible in WinCC v11.
But I prefer to keep the existing objects dimensions, and adjust everything manually.
If you choose to let WinCC fit automatically, there will be small rounding errors everywhere so it will not be so pretty. Circles becomes ovals for example.
Guess I'll do it manually then ;-) Probably it won't take that long as soon as I get used to v11.
Thank you for your answer.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
250
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
484
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
95
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
296
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
217
