Changing priority from absolute to symbolic (and vice versa)
allanlewis
May 2009
London
I have a program that normally uses symbol priority. I wanted to rename some DBs, so I changed to absolute priority, did the renaming, ran a consistency check and recompiled. As I said, I normally work in symbolic mode, so I changed back to symbol priority, but now I can't recompile without going back to absolute mode. (I get lots of errors from symbols pointing to the old DB names.) How do I get Simatic to "save" the new DB names permanently so I can compile symbolically in future?
I have noticed that if I edit another block (not necessarily one of the DBs I changed), save it and recompile the project symbolically, I don't get any errors and everything seems fine. Is this correct?
It is extremely rare that I change the symbolic name of an existing DB, but when I do I find that I have to go in and resave all the affected blocks before switching back to symbolic. Reorganize seems not to be sufficient.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
262
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
502
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
101
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
303
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
225
