Changing ratio in MAG instruction while active
capsuleguy
Sep 2019
High Point
Our motion project uses a MAG instruction to gear a motor to a CIP encoder. That works great now. We now want to adjust the gear ratio based on some some sensor data. We created a tag for the ratio and I see it changing in the MAG instruction, but the motor speed isn't changing. Do we need to start a new MAG instruction every time we send it a new ratio? Note that these are tiny changes in ratio.
Thanks!
All motion instructions are one time instructions. Nothing changes until you issue another instruction (or issue the instruction again).
You don't need a separate instruction. After you enable/issue the MAG instruction the first time, you don't need to leave that rung true any more than the first scan. When the ratio changes, enable the rung again for a scan.
Be sure to pay attention to the Clutch and Accel settings in the MAG so you don't try to instantaneously change speeds
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
266
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
506
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
103
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
306
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
227
