Changing RSLinx from a service to normal application
Derek Scholes
Jul 2003
I have been using a laptop connected to a SLC 5/04 via the DF1 comm port. I can remove the DF1 driver and replace it successfully.
However when I try and replace the DF1 driver with PIC it returns a message that the RSlinx is running as a service and must be restarted as normal application.
Can anyone explain how to do this please. The laptop is running Windows 2000.
Many thanks (in anticipation).
Derek
I have searched for a thread but have found none. the problem I am having is the box under system comms that will let you click to change only...
2,202
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
236
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
472
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
92
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
289
