Changing the station number of Step 7 200 PLC
GO ONLINE WITH S7-224 DEFAULT ADDRESS IS 1, OPEN SYSTEM BLOCK IN PLC AND SET NEW ADDRESS. NOTE WHEN YOU CHANGE ADDRESS YOU WILL HAVE TO LOG ON AGAIN WITH THE NEW ADDRESS.
Has Siemens changed their policy on addressing?
Mike Nagy wrote: DEFAULT ADDRESS IS 1
As far as I know all S7 PLC's come with their address set to 2 as default. All my S7-314's, -312C2DP's, -212's and -214's were delivered with their address set to 2. I have however never used an S7-224, but I don't see why Siemens would change this. If they have somehow changed their addressing policy this would be major information. Please clarify.
I have also never changed, or even opened, the system data block. In my version of the software (an older one, I know) I can simply click on the menu bar on CPU, then on Configure and there it is: a screen to configure my CPU, including the address of the CPU on the PPI network.
Kind regards,
Changing PLC address
Hi Mike
Thanks for your reply I am about to try the change. I have to agree with Jean Pierre about the default address for the initial station being 2 and not 1. As I understand it the Station 1 is reserved for any HMI.
Many thanks for your help.
Derek
Hi, Is there a way to change an existing FactoryTalk application (FT 8.10) from a Network Distributed application to a Network Station...
6,020
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
236
Hi all, I am having an issue where some of my HMI push Buttons and Indicators go in to error when I navigate to a new screen. I am using a...
472
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
92
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
289
